Hey here i am again!
i have a big problem. i have deinstalled most of the sony vaio programms that where installed and now i cant use the buttons which work with the Fn Buttton (+ - and so on)
there was any body who said i should go to C:/Utliy"??
but ther is nothing that is comperable with this (Utl...)!
so what program or what driver is responsible that this buttons work.
so can any bady help me ?? (i would prefer not to use the preinstalled programms because i dont realy need them!)
thank you!
i drive a Sony Vaio VGN-FS295XP
1) If you don't uninstall VAIO recovery tools, you can use it to create folder C:\Util.. or Applications
2) If you have recovery CD, you can find there folder named VAIO Applications/Applications
hi do you speak german??
weil dann könntest dus auf deutsch erklären *gg*
thank you!
I know only russian and some english...
hi!
is that on the recovery cd?
what is that utli... that are all the programms that where installed?? but i only want that this buttens work again
;(( do i need a driver or what???
On you recovery CD you can find "[CDROM]:\VAIO Applications\Applications"
I recommend you to install all utilities in folders named "Utils Installer 1,2...", because this is very important tools, for example vaio power management or vaio control center...
Joop, grüße dich
du kannst die Tasten wieder nutzen wenn du die Vaio Utilites
wieder installierst
Entweder auf deiner Recovery CD
oder zum Download auf
http://www.vaio-link.com/index/index.asp?l=de
viel Erfolg:smileygrin:
