Hi Does anybody have an idea what could be wrong with this laptop. When first switched on the display flickers to the point of total whiteout, back to just slight shimmering very rapidly. Clean install of windows xp pro. BIOS update to ro103k7. ATI update from sony website, all carried out. After 5 to 10 minutes gradually settles down to solid display, sometimes flickers briefly during first hour or so then is ok. Any advice gratefully recieved, Thanks. Almost at point of ripping hair out!!:smileycry:
I'm afraid it is a hardware problem, it comes up quite a lot on the forum here. As I say, as long as it's within warranty Sony fix it for free so don't worry too much. It's just a few days without your computer unfortunately when it gets sent off.
At one point, I was able to painly access the control panel and change the screen resolution... and *poof* the flicker was gone ! I did that about 2 or 3 times.Using the notebook in a native resolution is recomended.
If you set the resolution higher than it is supposed to go then things are probably going to get funky in one way or another. You might even do some real damage.
Best having it looked at under warranty.
