every time i turn on my laptop my firewall is down and i have to turn it back on.
ap untill a month ago it was on all the time i only turned it of manualy when i wanted to....
how do i make it be permantly on like before without having to do it manualy?
Zina,
The firewall not automatically enabling at boot can be symptomatic of a virus/trojan on your system.
Let¿s hope that isn¿t the case, but which firewall are you using and the version?
If you are using Norton then in Options > Auto Protect you will shoud find a check box for "Start auto protect when windows srarts up"
you could add the firewall into the autostart.
LOL
LOL
LOL, of course. That's it.
German Windows is a bit different.:smileyblush:
no problem :smileygrin:
Lizzie,
The safely remove hardware icon should be there in the system tray by default. There is nothing in the start options or services tab of msconfig that covers this.
However Windows has a glitch, insomuch as although these processes are running they occasionally fail to appear.
One workaround, if it is not visible in the tray, is to log off and then log on again ¿ not very convenient but it usually works.
i had norton but the subscription has finished you think its becuase of that?
but it still works when i TURN THE FIREWALL ON MANUALy.
i thougt firewall was from windows
