Hello
I Have some problems with my Sony Vaio AR11B after reinstaling my system from XP Media Center to XP Pro. I had to do it becouse I bought my Vaio in Germany and I'am from poland. I could't work on German Windows XP becouse I didin't understand anything. Here are the problems and questions:
1. My Windows doesen't shut down. When I klick to shut it down it freezes on the last screen when it's trying to shut it down. I have read some topics on this forum but I don't know what to do. Please HELP !
2. What Drivers I should dawnload for my GeForce Go 7400 ??
3. When I bought my Vaio I had installed all programs on it, like SonicStage, Sony MasteringStudio etc. From Where can I get them ?? I haven't been given any CD when I bought my Vaio. Only 1 with Films
4. I Dawnloaded some drivers from the Support page but most of them I Can't instal becouse they doesen't recognize my Notebook as a SONY VAIO. What should I do ??
5. After Reinstaling the system to XP Pro all of my hotkeys stoped working. The only one's that's working are the +/- Volume & Mute Sound. The Rest as AV MODE (STOP), (NEXT) , (REVIOUS) and important The Open CD Button wich is situated near the Mute Button Doesen't Work. Can somebody Help ?
IF anybody knows how to solve my problems please answer
Perfect! Glad it worked
i will re-install XP Pro right away!!
// CrazyCow
Yes, it really did the trick for me!
Sony made the hotfix available at the following location:
http://esupport.sony.com/US/perl/swu-download.pl?mdl=VGNUX180P&upd_id=2228&os_id=7
Otherwise you have to contact Microsoft Product Support Services to obtain the Hotfix.
Thanks CrazyCow
Try calling Microsoft Sweden?
i need step by step procedure what to do with nlite...
thanks...
*****.... i Can't install it becouse my languge is diffrent 😕 .... my XP is polish .... **** !
Edited - Profanity
*****.... i Can't install it becouse my languge is diffrent 😕 .... my XP is polish .... ****!
I'm using a swedish version of XP Pro and worked around the problem with a USB hub. Read more here:
http://www.club-vaio.com/clubvaio/mvnforum/viewthread?thread=35725
// CrazyCow
So I must buy a USB Hub ?? It is the only way ?? I don't have to install these drivers ??
You have writen a solution with the Motion Eye (Camera). I need it all the time, Do I have to Turn it off ??
Yes, I think thats the only solution on a none english operative system, no patches are available. You could try to find a English version of XP Pro and then install the language pack, in that case the 909667 hotfix will work.
What exactly do you mean by "don't have to install these drivers"? Are you referring to the drivers for the internal USB camera or the USB hub?
In both ways you don't need to worry about any drivers since camera and hub will work once you finished the installation of XP Pro.
hi all,
i am trying to do the install as you menton using the driver pack from sony but i am having problems getting the sata and raid drivers to work on my vgn-ar11s.
My machine is basically saying it cannot find the appropriate driver int hose files, anyone have any ideas?
I have tried this remaking an xp pro cd or using the f6 option with a boot floppy.
Thanks!
