I know this is kind of a double post, but I thought it better under a new thread than in the unrelated one
I logged a case today, more of a clarification of the aceptable faults with current model. It's a FE21M and my only issues are,
1.) the dark areas in the corners of the screen, which I believe are common on this model (I am quite dissapointed in Sony's X-Black range in genral)
2.) The keyboard has a slight bulge on the right hand side, I don't think its a danger to screen or anything, but i generally use a wireless keyboard and dont transport it much at the mo, If pressed down on at the bulge you can depredss it ( basically the keyboard floor moves down) but it isn't a huge issue, especially as its a better specced laptop than my previous and the upgrade was free, so I don't want to sound like a padantic mofo.
So also if anyone reads this with same model can they post if they have same thing on their machine and clarify if this is common, thanks
hello m8 read comments - i have none of these probs but i have a problem with the sound - it is awfully low on the highest settings - i have changed bios to vol=8 & yes it has helped but when you test with a tosh or a dell then they blow this to bits - has anyone got any ideas i have opened a case with sony as this is never right & i should nt have to use vlc media player just to get a bit more wattage
Andy you're an omen to these VAIOs
Seriously though that sounds rather annoying
I have neither of the problems that you mention with mine
Mat
Hmm, I have read other posts about the darkness in the corners of the screen, I thought it was media centre scheme to begin with,is just right in the corners really. THe bulge in keyboard is not very bad, just a little bit weird. I will wait for contact form e-support to see what they say.
Thanks for the comments guys
I am the DAMIEN of Vaios! Grr Sonic Stage thingy "Connect" I signed up for it last night, went to get my free album, it told me to enter password for confirmation, and wouldn't take my password! so I asked them to send me a new password, I asked twice last night (well more like 2am) and still no email! grr
