HAS ANYONE ELSE HAD TROUBLE WITH THE FINGERPRINT READER ON VGN-AW11Z?
WHEN CLICKING ON ICON IN BOTTOM RIGHT HAND TRAY RECEIVE MESSAGE:
Cannot enroll user.
An internal error occured (pt: tfmerr -1118).
ERROR IS INTERMITTENT AND READER WILL SOMETIMES WORK.
ANY SUGGESTIONS?
Hi sonnyaw and welcome.
Intermittent faults are not good as they often point at hardware as the cause.
However, I would try reinstalling the fingerprint driver and seeing if there is an updated version on the web. I think you have Version 1.9.2.111 installed and there will almost certainly be a newer version on the UPEK site: -
http://www.upek.com/support/downloads/drivers/windows.asp
If that doesn't fix it you will need to contact Sony Support as a repair may be needed.
