HI everyone, I have a problem with my Vaio VGN-A215M : since some months ago, the fan cooler remain ever turn on!! Someone knows what it could be?? thanks
I have the same problem as many here have.
It's any cheap <profanity removed by moderator> from sony!
But I think, there's no solution.
Ciao
Ladgaz
Hi ingling and welcome to the forum.
A good start would be to check your CPU temperature with MobileMeter . The processor fitted in your model should ideally be running in the mid 40’s/low 50’s deg. C.
If you are experiencing higher temperatures it may help to clean the cooling vents with compressed air.
