I have a problem with my harddisk in my FS415S
Write Speed Average is smaller than 2MB/S
what can i do?
Extrem slow Harddisk FS415S
what can i do?
How are you calculating this speed.
Are you transferring data from another source.
How full is the drive.
Have you tried checking the disk for errors.
When was the drive last defragmented.
Check the Device Manager. In IDE ATA/ATAPI controllers the Primary IDE channel the Transfer mode is set to PIO mode (most likely). Change the setting to change the Transfer mode to "DMA if available" and it will change to Ultra DMA Mode 5. This should make the HDD quicker and get rid of a clicking/lag sound when playing back audio (experienced it myself).
Lemme know if this sorts you out!
