Can you run programmes from an external hard drive? If so, do I install programmes direct to the external hard drive, or install to the laptop then cut and paste?
Sorry if this is a basic question but I don't want to wreck anything!
cheers
yes you can install programs straight to the external harddisk but you can not cut and paste you must reinstall the program then select the external hardisk as the installision path
