I have a Vaio TX3XP and bought a Fujitsu external display 19" 1440x900. The display looks horrible, and I have tried to set the resolution, but it doesn't help. When my Vaio says I have set it to 1440x900 the display ays it is 1152x something. What do I do thats wrong or doesn't my Vaio support this resolution on an external display?
Thanks in advance
Hi sbwal and welcome to Club Vaio.
The resolution of your Vaio screen is 1366x768 and it is possible you cannot exceed this.
Have you looked in
Control Panel>Display>Settings>Advanced>Adapter>List All Modes
To see all the available resolutions.
Did you get a disc with drivers for your Fujitsu Display and have you installed them?
