I would like to install Expression Web software on my vaio netbook (vgn-p11z). Does somebody have experience with this combination? Is the small one strong enough to run the software???
thank you
Welcome to ClubVaio Superbex,
Considering that I have a P-Series myself, I do not believe that your computer is strong enough to use this software without headache.
After read the website and compare the different requirements to use the software, I can say that... for sure, you will be able to use the software, but it will be necessary a lot of patiente from your side.
I saw that you can download a trial, so... give a try and find out by yourself...
thank you!
