Hi
6 weeks ago I bought a VPCCB3PIE laptop and almost as soon as I started using excel it crashes. Sometimes I can open a spreadsheet and be on it an hour with no problems but more often than not, after just a couple of minutes the EXCEL.EXE is not responding icon comes up and the screen behind becomes faded and the mouse icon turns to the blue circle. I get the option of restart the program or recover the program. Neither of these ever works and after waiting for 30 mins or so with the same screen, I get bored and turn the computer off at the power button as when excel fails, it seems to disable all the key and mouse functions as well. On turning the computer back on, I get a recovey screen which states that windows shut done unexpectedly and normally on re-start everything appears fine.
Any ideas??? It only seems to do it on excel
Thanks
There are 3 step to repair excel keeps crashing error
If you got excel keeps crashing error then there is a 94% chance that your computer has registry problems. To repair excel keeps crashing error you need to follow the steps below:
* Step 1 - Download a excel keeps crashing error repair tool,install this error repair tool.
* Step 2 - Click the Repair All Button.It will scan you pc for Free.
* Step 3 - Then click the Repair All Button again and your done! It is very easy to repair excel keeps crashing error.
Get more information http://answers.yahoo.com/question/index?qid=20100917194829AACc5aO
_______________
Life is too serious to be taken seriously
Thanks very much, I'll give that a try
Thanks
Dear Sapna,
You can use a third party data recovery software to recover your damaged excel file there are so many software which help you one of them is Kernel Recovery for Excel you can download this software from here
http://www.excelfilerepair.net/
Thanks
recover Excel quick and easy recovers damaged Microsoft Excel files. It can help the users to avoid the loss of important data most often processed using spreadsheets, such as statistical, economic, science information, etc.
