Hi all,
I have vgn a-497xp and i am having a problem with my ethernet port.
I have to move around the clip until i get connected. What should i do??
Thanks.
Sounds like a dodgy cable, try another if you can
If it works when you move it, it has to be a bad connection.
If changing the cable doesn't work then it must be the socket.
If your Vaio is still under Warranty contact Vaio-Link - if not then a local repairer may be best.
Short term you could but a PCMCIA Ethernet Card or a USB Ethernet Converter
Yep as Blencogo said it's a problem with the socket
A little trick:
it's possible (unlikely but possible) That the 8 little metal pieces in the socket (the cupper things that contact the cable) have been bent down a little, so they aren't pushed to the cable well enough.
You could take a needle and gently lift the little cupper plates a bit, so that they are nicely pushed against the cable's cupper wires when you connect it. Be gentle though, so you don't damage the socket.
Greetz,
Joren
