Own the RA204. Been using the ethernet connection for an adsl router (internet connection) Worked fine for a few months and then stopped working.
Can't discover why. Can't access the router page via the computer let alone the internet. LED on router indicates a faulty connection....
Checked the cable. wondering if its an adapter or driver issue.
Any ideas anyone? Help greatly appreciated!
Hi rayman and welcome.
My initial thoughts are that if you can’t access the setup page (via your browser) for the ADSL router then it is probably a hardware problem. Have you tried the re-set button on the router?
Edit: also check your firewall settings or turn off fire wall and try accessing the setup via browser.
