I have Windows 7 Ultimate - 32bit
Thank you all in advance.
Message was edited by: billef
I think i resolved my SD probelm - for now - I downloaded a driver RIDFMC-70165670-32.exe - It was also selected from windows (i went to device manager and selected the "Scan for hardware changes")
The /t, /p or /w on the end of the model VPCW12J1E just refers to the colour - black, pink, white etc. The drivers are the same for all three.
You can download all the drivers from here: -
http://support.vaio.sony.eu/computing/vaio/downloads/preinstalled/index.aspx?l=en_GB&m=VPCW12J1E_W
You will see the 3 Memory Card Drivers and the Bluetooth Driver are there.
Thanks for the link. It got helped really! The thing now is that Ive installed my bluetooth driver but still something is wrong.
I have an iphone and a nokia device. I tried to connect my iphone with my netbook. Both devices found each other but there was a problem in the connection.
The problem located in the bluetooth peripheral device driver. its still missing. I tried to see what is the bluetooth peripheral device.
I went to --> bluetooth devices --> Show Bluetooth Devices. There were two devices icons (iphone and nokia - I also tried with nokia) and there was a notify triangle icon at the corner of each device icon.
I pressed right click and then i saw a troubleshoot option. I clicked on that. The result for each device was that a driver was missing!!! Why would I want a driver for my iphone/nokia device?!!! Is this really the problem?
