Hi folks, wonder if anyone can help?? Every day at 6pm this message comes up on screen!! "Error loading C/Program Files/Common Files/Paretologic/UUSZ/UUS.dll." I dont know what it is, or how to get rid of it!! so if anyone knows can you let me know!! Laptop hasnt been same since got a trojan virus!! also will not restore back for me!! cheers..
have you stopped the 'Error loading C/Program Files/Common Files/Paretologic/UUSZ/UUS.dll' error message from popping up by following the steps above.?
Have you scanned your Vaio for spyware/malware? If you don't have an anti-spyware program installed you can download something like Ad-Aware or Spybot S&D both of which are free..
Hi there, Yes, the error message has stopped appearing at 6pm, so thanks for that. I do have Antispyware installed, SpyBot.. and nothing showing on there!! If I try and restore the laptop like you said in Safe Mode, will this effect my laptop in anyway!! or do you think I should just leave it as it is???
If everything is stable now I wouldn't bother with the system restore.
It may be a good idea to create a system restore point now, use the following link for a guide should you need it: How do I... Create and use System Restore in Windows Vista
no
no
Hi there, Thanks very much for your help,, Not sure about other fella "No",,,like you say could mean anything!! I think I will now try and create a new restore date and see what happens.. will let you know. Your a star as they would say in Ireland. :smileygrin:
Have just created new restore point as from today, so hopefully all will be ok. Thanks again for all your help just wish I knew more about how these things work!!! :smileygrin:
You're more then welcome Carlowlass..
