Hi, new to all this and was wondering if anyone could point me in the direction of a great pair of "in ear" earphones - the ones you would use for exercise. Ive heard Sennheiser are good but they 're quite expensive. I used to have sony groove earphones which were so comfortable but as everyone says, they just break too easily!
Thanks in advance
there is a pair of sony ones that are £30 and are meant to be really confortable. i also think it is a twist free cord. i am going to buy a pair later on
I have those, and I think they're great as they're nicely cushoned
I have those too, the total isolation from being "In the Ear" took me a bit of getting used to, but they sound great and have bass.
They now seem cheaper than they were.
I had to import my white ones :smileygrin:
I like the way they don't give you ear pains....
Hi there, took your advice and bought the MDR-EX71 yesterday. They sound great and are very comfortable... only problem is they keep coming loose when i go for a run! I'll keep them though. Are there any other good earphones i could try? Thanks for your advice
im am not sure.
I use them too, great headphones, have you tried using one of the larger rubber buds?
For running you probably need the streetstyle headphone which can grip onto your ears.
Otherwise it's back to the classic band.
