Hi all,
the sony dvd-rw, dw-d56a, combodrive can't be opened by pressing the drive open button. Only way to open it is the open submenu in windows explorer. I can hear and see on display the icon for the drive (looks like ^- "arrow above the line").
Is an option somewhere, where I have to de/activate the hardware drive open button? If not, what then?
Thanks for answers!
VAIO VGN-A397XP
2,0GHz
512Mb RAM
80Gb HDD
DVD-RW "Matsushita"
Mmmh, can you fix the problem with an system restart?
other point : there is a tiny hole on the drive. That's a button, with this you can open the drive. (I mean not the tiny hole on the bottom from your laptop!)
Have you installed the utilities from C:\Utils\
