Hello..guys..
i bought my laptop FS25 on Jun 2005, but rite now my DVD RW can't read any CD or DVD or Write as well.....damn <profanity removed by moderator> how to solve it...pls help..bcos now i was in asia .....:smileycry:
I am also in Asia. I am living in Shanghai and have exactly the same problem as you. My labtop is FS115Z then if you got any good any solution please let me know...
Over the past year I think there have been a numbr of posts about DVD problems with various vaio models. My S series DVDRW packed up after four months! I was abroad but fortunate enough to have an international warrenty which meant that the local Sony branch fixed it without any hassle. Do you have an international warrenty?
Sorry I can't offer any technical advice.
The FS series often have either the Matshita UJ840D or the DW-D56A optical drive fitted. There have been a number of posts on this forum concerning problems with both of these drives.
There are firmware updates available on Vaio Link but I have not seen any reports that this has cured the problem with the DW-D56A, not sure about the UJ840D. If the update makes no difference then I am afraid that it appears the only solution is to replace the drive.
I agree with Rich912.
I'll even tell you why these discussion boards are filled with topics like this one. A dvd-writer (and reader) are just like a human heart. A heart beats for x-times and then it stops. This is the same with writers, because it produces heat and has a laser eye and turns, they will stop working before the rest on your computer.
I'm not discouraging you to use your optical drive(s), it is just a general fact that these are the first things that will stop working properly. Ofcourse there are also manufactering problems with some, but it is impossible to test every model.
I surely hope a firmware update will help both of you.
Good luck and enjoy your time in Asia
