i insert a blank dvd and i try to open it to write some files to the dvd and F:/is not accesible i have this error.I have a sony vaio vgn-fe21b
I'm not sure there, but your VAIO does not support DVD-RAM.
Your drive supports: -
CD-ROM : 24 x Speed
CD-R : 24 x Speed
CD-RW : 24 x Speed
DVD-ROM : 8 x Speed
DVD +R : 8 x Speed
DVD +RW 8 x Speed
DVD -R : 8 x Speed
DVD -RW : 6 x Speed
DVD Dual Layer : 4 x Speed
But Windows does not support DVD writing - you cannot just drag-n-drop files. You need to use Roxio DigitalMedia to save your files to a DVD.
No my dvd read's dvd's(writen) and cd's but if you insert a blank disk and go to the roxio the cd or dvd is'nt work.
solve this problem but i dont know exactly how. :smileygrin:
