Hi All,
On my Z1XMP when I try to run a dvd is comes up with an error message. It worked ok at first but now seems to have a software problem. Does anyone have a solution for this ?
What's the error message or code?
The message I am getting is -
Error signature
Appname wmplayer.exe. AppVer 9.0.0.2980 ModName.iviaudio.ax
ModVer:1.0.0.1 Offvser: 0001125d
This means nothing to me !
Try reinstalling Intervideo WinDVD. Also try playing the DVD using WinDVD
Hi Rob,
I re-installed the Win-DVD software and this seemed to work. Everything is ok now.
Thanks for your help.
Regards,
Bill
No problem Bill, happy to hear you sorted it out.
