hi,
what's the best solution to get a dualhead/view for this computer?
driver update?
or change the graphiccard?
course i read that there is no dualhead support for the gforce4 ti 4600.
maybe someone has an answer.......
buster
Check page 48 of the user manual. A dual display configuration is unfortunately not possible with the preinstalled graphics card. The only solution is to replace the graphics card.
thanxx
buster
some one has done it mate
your card should do it mate same as mine should i have a sony rz 104 desktop with a geforce 4600 ti. i posted the same question the other day
just been told to uninstalll the drivers and reinstall the\standard ones. but havent managed to do it myself yet.windows xp keeps reinstalling them for me
look at the post on page 1 titled
Geforce 4 bios configuration
ifyou have any joy let me know
regards
scott lewis
