Does any one know if it is possible to use both of the video outputs (VGA and DVI) on the VGPPRZ1 docking station, so that you can have two external monitors connected to VGNZ11 laptop while it is docked?
If so do you know how to do this, as i am only able to get either one of the external monitors working along with the laptop screen.
Hi MarkShea,
welcome to Club VAIO..
The docking station will support either VGA or DVI but not both at the same time..
Something like the Matrox Dualhead2go should allow you to connect two monitors to your Vaio, use the following link for more information: Matrox Dualhead2go
