I formatted my HD recently on my VGN-A317M and I'm setting everything up all over again. I went to the Sony support site and got the pre-installed drivers. This worked fine except for the Memory Stick driver and the Touchpad driver. Neither of them would set up. Does anyone know where else I can get working drivers?
Thanks a lot.
Start the Devices Manager. Doubleclick the unknown device(marked with an red X or yellow ?). Click on the Tab "drivers* and click update. Select the folder with your MemoryStick driver and click OK.
Do the same with your Touchpad. Just click "Pointing Devices" and doubleclick the PS2 mouse. Then update the driver your Touchpad driver.
HTH
When I went there "Ethernet Controller", "Mass Storage Controller" and "Modem Device On High Definition Bus" have yellow ?s beside them. When I select update driver I get the message "The hardware was not installed because the wizard cannot find the necessary software."
By the way, my touchpad is actually working, I just can't scroll with it and there's no interface for configuring that like there was before.
By the way, my touchpad is actually working, I just can't scroll with it and there's no interface for configuring that like there was before.Windows recognize your Touchpad as a PS2 mouse. That's why you can't scroll. If you update the driver with the Touchpad driver, then you get the features back.
Sweet, it worked. I believe everything's back to normal now. Thanks guys, I really appreciate the help. Just one more question though. Where could I get Vaio Zone? The only download I could get on the driver site was an update, and I must have had the original installed fro that to work. I can't find the original anywhere.
Thanks a lot again.
