I have just used the Vaio Care on my laptop and found I'm missing a driver. It's telling me I need the Sony Firmware Extension Parser but when I enter the laptop model number to get the list of drivers this one isn't listed. Can anyone suggest where I might find it?
Thanks!
Hi catgeraghty and welcome.
Go to the Support Downloads page for your model here: -
http://www.sony.co.uk/support/en/product/VPCEA3M1E_P/updates
Look in 'Preinstalled Drivers and Utilities' -> Windows 7 -> and you will find the SFEP Driver about half way down the list.
Hi
Thanks for your help. I did find it as you said but now have another problem, when I went to install it I get the following message 'You have to run the 64-bit version of DPInst.exe on this machine'. Is this called something else in the drivers list as I can't see it.
Thanks again!
