Notbook Tap-11 (SVT1122M2R). 3G Modem drivers were lost (probably during upgrade Win8 - Win8.1). Device manager shows four Huawei Mobile Broadband Module, divers nor installed. There is no proper drivers at suport page (or I can't find it)
Where I can find it?
Hi max_woody_ru,
Is this by any chance the driver you are looking for?
http://www.sony.co.uk/support/en/content/cnt-dwnl/prd-comp/preinstalled_drivers_win8_9414/SVT1122M2R
Rich
Thank you
Unfortunately no changes, there is again four devices without drivers.
Hi max_woody_ru,
A contact within Sony has been asked to throw some light on the missing drivers. In the meantime can you check whether the drivers are available in Vaio Care > Advanced Tools> Recovery > Restore and Recovery > Reinstall Applications and Drivers (these instructions apply to Win 7 systems and I hope that Win 8 is a similar procedure).
Rich
Hi max_woody_ru,
Apparently, for this model, Sony uses the (standard) embedded Windows drivers, so these are not available for download on the Support site. Note that this means that the drivers are included with the original delivered operating system.
Did you follow the Sony upgrade procedure from Windows 8 to 8.1 or did you carry out a clean install?
Rich
Unfortunately I didn't know about special 8 to 8.1 Sony upgrade procedure. I've use standart upgrade via Windows Store.
Unfortunately I haven’t been through the upgrade process from Windows 8 to 8.1 so am probably not the best member to advise you. However below is a link to the Sony upgrade procedure for Vaio computers.
http://community.sony.co.uk/sonyeu1/attachments/sonyeu1/pc_en_1/132225/1/Windows%208_1Upgrade_EU.pdf
If you identify a step that you have missed I suggest that your best recourse is to back up your personal data, return the machine to factory settings (Windows 8 OS) and then follow the recommended upgrade procedure. This will hopefully retain the 3G drivers.
Rich
