2200BG driver doesn't work. It's a driver that isn't on the Sony Vaio site. I'm looking for the driver that will allow the laptop to search for networks. Does anyone know where to find it or what it's called?
I don't have the driver disk either.
The reason you can't find the driver on the Vaio download site is because there is no model called PCG-7G1M.
This is the chassis designation from the bottom of your Vaio - if you look on the screen surround you will see the correct model type which will probably be something like VGN-FS415E.
You can also find the correct Vaio model in the BIOS or in Vaio Control Centre.
If it is a VGN-FS415E you will find the Intel Wireless Driver and the WLAN Starter utillity here: -
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VGN-FS415E
You don't say if you are using XP, Vista or Windows 7, so make sure you use the correct driver. For XP it will be in the Original Drivers Package and foar Vist it will be under the Vista Tab.
Alternatively, the drivers are available on the Intel website here: -
http://www.intel.com/p/en_US/support/highlights/wireless/pro2200bg
Again there are different versions for XP and Vista.
