Hey folks....
the surface of a onyx-black display is somewhat more rugged thanthese matt black older displays like on my GRT785B... if you should ever happen to sneeze or caugh or talk spit-balls towards you display, then wipe it off emediately... if you let it dry it will scorch that top matt surface... and one other thing... never ever try to peel an orange while sitting at your notebook.
Joe
Yeah Apple suggest Klean Screen, Samsung suggest something else, it's all a matter of taste, but they all say don't use paper towels, whcih is wise.
So Brillo-Pad on those tough to move bits is a no-no then?
Mr Muscle sink and drain cleaner isn't recommended either
And Domestos is a big no-no
I have found that the cleaning material is not a problem, but putting the laptop into the microwave to dry it afterwards is......hmmm
Hehe wow now that would make "fireworks"
It is the easiest way to get the following files to work
SMOKE.EXE
SPARK. EXE
SIZZLE.EXE
BANG.EXE
MELT.EXE
WARRANTYNULLANDVOID.EXE
Hehehe and yourwifeispissedbecauseyouboughtanew2000quidlaptop.exe :smileygrin:
Not a problem for me at the moment ...I have 2 weeks of bachelor bliss left....
