Hi, can anyone tell me how to display Lyrics on my VP?
I have i have inserted the lyrics through Sonic Stage, but when i download to my VP and press the lyrics button, nothing happens.
Many thanks
Your mucis has to be in atrac form to view the lyrics in the vp.
if you transfer your mp3s or other music files,your already-attached lyrics will not appear.
Plus i think you must have installed the firmware update to do even that.
hope that was helpful
Hi MadarbWoT...
I tryed to transfer some archives to my VP with lyrics... i convert this files in ATRAC PLUS mode 225.. ok... i have the new firmware installed but when i have this files in my VP and try to read the lyrics, nothing happens same as "Kuka Kid"
Did you see the lyrics any time in your VP?? I can't find in the help of the SonicStage a line saying all for this function....... ggrrrrrrrrrrrrr
Hi, It works, Hooray, I like you, i was converting to the highest bit rate. This is the problem. Lyrics will only be displayed if you transfer at the lowest bit rate. I am strill trying to determine if i loose much quality at this rate? Kind Regards:smileyhappy:
Thank you very much kuka kid... the lowest bit rate in ATRAC is 48kbs puajjjjj
veeeeeeeery bad...
JC
