How can I disable McAfee on my new VGN FW31M so that I can try AVG. I want to eventually uninstall it as I use AVG on my main PC but for now I just want to disable all of it's components.
Thanks for any help.
Rob
Welcome to Club Vaio The Hollies,
I wouldn't recommend you to have to Antivir solutions installed at the same time, if you consider to choose AVG instead of MCAffee use this tutorial to uninstall the preinstalled software:
http://service.mcafee.com/FAQDocument.aspx?id=TS100507
DON'T delete it yourself via Software or explorer!
Many thanks for your swift response, benste.
I am just following the link now.
Cheers. Rob
No problem, enjoy it cause McAffee is known as a power cunsuming software 🙂
