Probably being a dumb ass but how do you delete tracks from a playlist?:smileyconfused:
I don't think this is possuible from the VP, you would have to do it via Sonicstage.
yeah you can. Go to the track in the playlist window and hold down the corresponding button second from the right - once you'vve held that down for a couple of seconds it opens up the advanced features bit, which lets you delete tracks from playlists. can't remember which icon is that though, have a play's my best suggestion, or downoad the pdf VP manual which has links pointing to it in various posts on here
