Could any Vaio expert explain how I can disablle the Debugger checks on my VGNN21M I keep getting a "Run Time Error Message" Carl
What is the full message and what are you using when it happens?
Hi thanks for your interest, I notice this happens occassionally when performing certain functions, The message goes something like"Run Time Error line....." do yo want to debug. I believe there is a facility wher you can tick a box to disable this type of message. Hope this may help
Try this: -
In IE7, click Tools -> Internet Options -> Advanced tab.
Check "Disable Script Debugging (Internet Explorer)"
Check "Disable Script Debugging (Other)"
Uncheck "Display a notification about every script error."
Hope this works!!!
