HI my name is Joao, i have a sony vaio pcg 61211m and recently i broke the screen, i order a new one from ebay and replaced it, the problem is i can see something on the screen but the image is too dark and even if a change the brightness it doesn't help..
I dont know if i need to buy anything else beside the screen... if someone could help i would aprecciate it.
Thank you
Joao
Message was edited by: jpfaustino
Message was edited by: -Cass-
Removed users surname to protect users identity
Hi Rich good morning, i will try a new screen and changing the cables and then still doens't work i will try to find a repairer as i am not very confident trying to fix the fuse on the motherboard.
Thank you for your help
Joao
Good luck Joao, and please let us know the outcome as this will no doubt be of help to other members.
Rich
Hi, thank you for your reply,
But when a switched the old screen the only cable i unpluged was the one i highlighted on the photo, i was looking for the inverter but i cant find it... Sorry... is it possible that it doesnt have an inverter because it is an LED screen ?
Thank you
Joao
No problem as soon as i have something i will post it. from what i read i am not the only one with this issue.
Thank you
Joao
Hi, thanks for that advice...that's the closest theory so far and I will def do what you recommend!
_______________
Life is too serious to be taken seriously
