Hello my name is Warren and i recently bought a sony vaio laptop CW series, however at various times my laptop freezes and displays the blue windows screen where it talks about dumping temporary files and restarts my laptop, also i have had problems with the screen sleeping, some times i will turn off the screen or it will do it automatically and wont turn back on ?? so i have to turn it off or take out the battery, if anyone could help me with my problems i will be extremely grateful.
Hi Warren,
welcome to Club VAIO..
For the shut down problem have you checked if there is a BIOS update available for your CW.?
To check open Vaio support, either by clicking Support at the top of this page or use the following link:Vaio support
Under Log-in option 2: Select your VAIO model, next to Select Model Category - Select your model from the drop down list, in your case VPC CW.
Then next to Select Model - select the CW model that you have
Then click Log-In
Once logged select Downloads, then updates, scroll down the list to check for a BIOS update and follow the instructions..
If that does not help then I suggest you contact vaio support for further assistance.
As to your Blue screen could you supply the exact message that appears.
