Does anyone know if the 20Gb and 40Gb Players share the same cradle?
Many Thanks
I think they do, both use the VERY CHUNKY cradle that the 40Gb uses. Got shown the 20Gb when i bough mine and it looked exactly the same.
Afroassasin
not sure which model you mean....
but if its a 40 gb vaio pocket, then no it will not work with the other type of NW series slimmer walkman
