Hi
Does anyone know how to force the CPU speed up on the A217M. I've tried changing the options in the power management settings (adjusted for performance on battery power), but this doesn't seem to increase the speed from 221Mhz. The CPU doesn't seem to want to throttle up when plugged back into a mains supply, either.
TIA
Si
As far as I know, the processor clock speed goes up and down when you need it to save power/boost your performance. If you look again when running a game or something, it will no doubt have jumped to the maximum. Rest assured it is working at full when it needs to. If you only had 200Mhz I doubt XP would even start.
It's speedstep technology, it knows when to throttle
I wish they did something similar for my brain! :smileygrin:
CW
EMLOL Woody!:smileylaugh:
That's the problem - when running flash applications in IE, the CPU speed is stuck at 221Mhz, and the apps run cripplingly slow. It's fine when plugged into the mains, it runs at 1.6Ghz (stock speed), and there are no slow down issues.
Ah now that is odd.......and I can't really think of a good way helping you, I'm pretty sure there's no effective way of manually boosting the speed up and down.
Check you're not using adaptive mode on battery
At work at the moment but I'll check when I get in. Thanks!
If it is set to adaptive mode, what would it need to be set to - performance? (that's what it's set to on mains power, iirc).
Yeah it should be performance.
