Hi Guys,
I need help. Anytime i plug a network cable into my vaio, My CPU usage goes up to a 100% and my vaio stalls. I am suspecting a malicious script trying to access the internet but i just cant find it. Out of frustration, i am planning to format my Hard drive. Can the recovery cd be used to re-install windows Xp (Home) on my machine if i do this?
Thanks, i hope i get some help soon.
KobiQ
Yes, the recovery CD will re-install Windows and all of the software that came with the computer!
It will be like the first day you bought it!
BEWARE: Because of this it will also wipe all of your installed programs and data from the HDD, so make sure you have backed-up everything you need before the recovery!
Hope this helps!
CW
Go to Control Panel, System
Click on the Hardware Tab
Click on Device Manager
Click on the + next to networking devices
Right click the card
Click Uninstall
Restart your VAIO
This has worked for me as well - bizarre how uninstalling something, then reinstalling something works...
(Kee-Lo: You just hit 18,000 posts!!!!!!!!!!!!!!!!!!!!!) Congrats
Sorry if this sounds rude but JESUS CRIST, already?
18000!!!!!!!!!!!!!!
Many congrats
It wasn't five minutes ago when i was congratulating you on reaching 15000.!!
It's a good job Sony make strong keyboards! Or are you on your 12th one?
Hehe I hink I have used around 4 different keyboards to write messages here.
1) Parents DeLL
2) GRx316MP
3) Friend's RA104
4 MY RA104
