I have a Vaio notebook, model PCG-9E5M.
It has suddenly stopped displaying anything at all. The screen is completely dead.
The indicator lights appear to work and it is making a faint humming sound (implying that at least a fan is working).
I have tried many times in frustration to reboot, then just one time it all worked again. I later shut the notebook down and I am now in the same, non-working, situation as before.
I did wonder whether maybe there is a switch, that detects whether the notbook is closed, and that mabe that switch is stuck.
Anyone have a clue what might be going on here? Thanks.
Can you connect it to a TV screen or another display? It could be your inverter is dying.
I connected it to a standard PC monitor, but there was nothing (just a "no signal" message).
Have you tried pressing Fn + F7 while connected to the PC Monitor? This should toggle your display to the VGA output.
