Hi all again
I got the vaio notebook PCG-FX503, I posted about hard drive failure, and a successful replacement from an original 20 Gb ATA-66 to a new 80 Gb ATA-100... With this roomy hardrive I could increasy my possibilities, as long as I dont need either higher processor speed (Pentium III 1.0 GHz onto an Intel 815EM motherboard), RAM (I have 512 Mb) or video memory (standard shared 11 Mb).
The question is that I have this original CD-RW + DVD reader combo drive and I wonder if I could update it and change the original combo drive for a DVD-RW... have anyone of you done something like that??? Do you think I will have any compatibility problem??
Thanks you very much in advance
Best Regards
Raúl
Hi Raúl,
A major compatibility consideration will be the front bezel (drive fascia). If you can source a drive from the same manufacturer and model range then hopefully your existing bezel will be interchangeable, otherwise you should have no problem, assuming that the replacement drive has the same form factor as the existing.
Hi Raúl,
I think the best is taking out the old drive, and compare with the one I want to acquire
Please update as of your success!
