hi
i have norton fire wall installed and everything but the internet check says im at risk due to to ports one a ping and another a http or something
i was woundering if any one knows how to shut them
regards ben
Does it tell you exactly which ports? Because if you close ports 80 or 21 you won't be able to use FTP or HTTP.
hi kee-lo
it says icmp ping status open
port 80 status open
all the rest are either closed or in stealth
regards ben
sorry missed one
port 1025 unused windows services block
Port 80 is for http requests, so I'd leave that one.
Port 1025 is used by Messenger, your choice there.
Not sure about the other one.
The important thing to understand is what connections the firewall permits inbound and outbound.
Ideally, you don't want anything open inbound (i.e no-one should be able to connect directly to your PC from the net) but ICMP ping isn't risky in itself. ICMP ping will allow anyone on the Internet to find out that your PC is online, subsequently, they might try to exploit other vunerabilities.
Currently, M$ (microsoft) release their security updates every month around the 15th - keep a check on the Windows update site.
Note Kazaa and Skype require you to allow inbound connections as they are peer-to-peer (P2P) applications. There's a big risk that you could let a lot of garbage in via those doors.
Outbound connections should be locked down to those protocol/TCP port destinations you need access to: dns, http/80 and https/443, ftp/21 (UDP and TCP), pop3/110 and smtp/25 for email and whatever for IM (don't use it so don't know the ports).
WinXP SP2 will make Norton and other firewalls redundant when it's released (next month) - WinXP Internet Connection Firewall has been re-vamped, will be enabled by default & all unnecessary services are disabled by default.
