Now just like a lot of Vaio FE11S users I had the clicking sound where my hardisk is. People who suggest it is the hardisk working, please save me the trouble of telling 100 times it is not the harddisk working sound. I had enough laptops to know the difference.
DOWNLOAD CLICKING SOUND
Now what I would like to know is if there has been anyone who send his/her laptop to Sony back to let them check it out. If yes, I ofcourse would really like to know what sony told you or what you did eventually. It seems to me nobody knows the solution. I did call sony and told them everything about the problem. They said it was something wich is new to them. I gave them the club-vaio link where people posted about the same problem. This coming week I am going to send my laptop to sony, this clicking sound disturbs me a lot.
I know that there are previous threads about this Old thread about clicking sound link , but I wanted to post a sequal where people could post their experience and opinion. Please don't suggest me to open up my harddisk or laptop, and once again it is NOT the harddisk working sound.
What happens: "The hard disk makes irregularly a clicking sound which is pretty loud two. Most certainly is not a working sound. It sounds like something is hitting the plastic of the laptop or something else. When I shut down my laptop and restart the sound is gone for a while." I personally think it has something to do with the reading arm. The clicking sound appears always when the laptop is not working. It's like when the harddisk is not working it cant get into the resting position, and keep on trying. I hope sony is going to spend serious time on this problem, especially it seems to be a common problem.
Important suggestions and remarks of others:
hard drive is made by fujitsu & they have a diagnostic software tool on the fujitsu web site & when i ran it, the program said no hard drive found on laptop, i spoke to fujitsu & they said i should wait for later version of software to come out, which i will do! anyone who goes to fujitsu web site, the version i tryed is 6.40
This is the response I have received from Fujitsu regarding the issue: We connected this drive MHV2160BT to our analyser and installed Windows XP Pro, we did not hear any obvious clicking noise unless you place your ear next to the drive so it is very quiet even though this does go into sleep mode at around every 4-10 seconds (idle). I would investigate if you can further into the specifications and configurations fitting of your Sony Laptop.
Aaah... What a bad luck!
I receive my new vaio FZ21S 3 days ago, and I have this problem!!!
Hard disk is Fujitsu MHY2200BH
I guess the only way is to return it to Sony to fix it. I tried last two suggestions of hard shut down, it didn't work.
That seems to help ... at least it helped me ... The solution is simple:
Go to Start > Settings > Control Panel > Sounds and Audio devices
Click the 'sounds' tab. In the window, scroll down to 'Windows Explorer' and in the sub menu, highlight 'Start navigation'
Pull down the drop down box below, where it currently says 'Start' or 'Windows Start' and choose '(none)' instead. Click 'Apply', then click OK, and close the Control Panel.
No more clicking.
Ref.: http://www.help2go.com/Tutorials/Web_Browsers/Turn_off_Internet_Explorer_clicking_sound.html
please let me know if that helps ...
Why do use internet explorer when mozilla firefox is much faster and doesn't keep ' needing to close and apologizing for the inconvenience ' every session. My dad was also addicted to that blue E but he's over it now , i deleted the short cut from his desk top and now he won't stop going on about firefox.
well, I`m not happy with this HD problem in my FE11S but after installing vista and upgrading the firmware to release 14 the problems have seemed to stop.
finally everything is ok
thanks
I am unable to download clicking sound bit is it usually three clicks together then a pause?
You can still download it...fill in code in right corner on the top and wait 45 sec and then press the button free download.
Funny milestone more then 100.000 people have visited this page. Mustv given clubvaio a boost. Never thought when i started it would become this big. Just shows how serious this problem is/was.
Read back a bit or find my other post entitled how to possibly get rid of that clicking noise - works for sure.
Hi, i've got a Fz21m and i have the same clicking sound problem with the Fujitsu MHY2200BH, there isn't a solution?
I had this problem with my FE11S and I contacted Sony who sent me a firmware update on CD. This fixed the problem so you may want to try asking Sony for help directly.
