I recently had to have my Vaio wiped of all programs due to a virus. Click to dvd is no longer there and I can only see updates that can be downloaded from the Sony site and not the original program.
Is there anywhere I can download this? I also don't have a Vaio recovery option anymore so as to get original programs reinstalled.
Any advice appreciated.
Thanks.
Hi rothman12
welcome to Club VAIO Questions & Answers Discussion forum..:smileyhappy:
Unfortunately the applications that came pre-installed on your Vaio are not available to download..:smileysad:
You can however, if you wish, purchase a set of recovery discs from Vaio support which should allow you to restore the original Vaio supplied OS and applications..
You can find the contact details for vaio support by either clicking Support at the top of this page or by using the following link:Vaio support
Under Log-in option 2: Select your VAIO model - Select your model from the drop down list..
Then next Select Model..
Then click Log-In
Once logged select Get In Touch..
