Hi All,
I have a vaio FE31m laptop, and I was wondering if it is possible to change the hard disk and the video card. The hard disk in this laptop is a 160 gb 4200 rpm FUJITSU, and is kinda slow by now :). Are there any compatible hard drives for this model? I've searched the net, but couldn't find any info. I'd prefer to update to a 7200 rpm.
The graphics card is a nvidia 7600 GO with 128 mb dedicated memory. Is it possible to also change this card?
I've upgraded the memory, now have 2 gb which runs @ 677 mhz.
Manufacturer :Corsair
Part Number :VS1GSDS667D2
Type :DDR2-SDRAM PC2-5300 (333 MHz) - [DDR2-666]
Supported Frequencies :200 MHz, 266 MHz, 333 MHz
But according to pcwizard2008 it runs at 333 Mhz? I'm a bit confused here...
So any help on these things would be great
Hi Lee,
to avoid confusion lets use this thread, instead of your other similar thread HERE..
Wow, thats for that, that is really useful.
