Hi all,
I have a PCV RX1 and my Hard Drive is out of order...:smileysad:
I have changed it by a new one, but i cannot use the 3 Sony CD to restore and reinstall my system on the new HD as i used to do on the old before.
I'd like to know if it's possible to do that ??? if it's yes, how can i do ??? if it's NO can you help me to reinstall XP and software from the CD's
PLEASE sorry for my english [:">]
bonjour,
j'ai un PC PCV RX1 and mon disque dur m'a laché... je l'ai remplacé par un nouveau mais impossible de restorer le systeme avec les CD d'installation fournis comme je le faisais avec l'ancien disque.
y a t'il un moyen de quand même le faire sinon comment réinstaller XP et les programmes du CD d'installation ???
Merci
What happens if you try to do the restore?
nothing,
it ask me if i want a standard restore or advanced restore as usually, i try both but nothing happened after. over one hour still nothing, it seems that the restore starts after i choose advanced or standard it is still running without end......
