hi! i reinstal windows 8 on my PC and lost all VAIO setings and can,t update my drivers!
what should i do?
Hi klicis89 and welcome.
How did you reinstall Windows 8? Did you use the ASSIST button and recover the pre-installed Sony version of Windows 8? If so, the software updating should be automatically reinstalled.
If you installed a commercially available version of Windows 8, it is likely that the Recovery Partition has now been erased. You may be able to manually install and update some drivers from the Sony Support website but you will not get everything working properly.
Did you make a set of Recovery Discs when you first bought the Vaio? If not, you may have to buy a replacement recovery disc set from Sony Support.
If you tell us what you did when you reinstalled Windows 8 and also give us your Vaio Model we may be able to help further.
