I hope someone can help as my laptop is about to go out the window and as its so easy to lift this is a real possibility!
Reacently, out of the blue, it wont write audio CD's properly. The first few tracks come out ok then they start to go downhill. Jumping and sounding fuzzy in the background until the tracks just wont play at all. I thought it was maybe because I had so much running while I was writing it but tried writing one with nothing else on the go and it didnt help.
Does anyone have any suggestions or have ever had this problem?
Thanks very much for any help anyone can offer.
Rea
Uit het raam gooien en een nieuwe kopen.
Rea,
Which notebook is it?
Make sure you have pleanty of space on drive C too and use a cleaning disc to clean the drive.
?????????????:smileyconfused:
Can anyone translate?
