Hello folks
The problem i have is - the cd/dvd will not detect when a dvd is in the computer, the tray will not open either when i press the button.
i have virus checked the machine and also checked for adware
your help would be greatly apreciated:smileycry:
Put a pin in the hole next to the eject key, then speak to Sony about the drive.
will this solve the problem
it was working this morning
isnt there anyway i can solve the problem myself
This sort of glitch happens from time to time.
Follow Kee-Lo¿s advice and you may find that the problem is solved after a re-boot.
You'll get your disk back which is a good start.
