my DVD CD drive has always worked fine but now it tells me to "insert a Disc in drive" when i am trying to access a CD that I have put into the drive. As if it the disc is faulty; i have tried a few diffent CD's and DVD's. Device manager thinks it is working fine. I have uninstalled the drive from device manager and scanned for devices. It picked up and installed my drive but still have the same problem. I can't reinstall from my VIAO recovery disc as my drive can't access it. Can anyone tell me where i can find CD DVD drive drivers on the viao website and what to do with them as i am not having much luck finding them. Massive Thanks to anyone who can help.
Hi donkeyfun and welcome to the forum.
Drivers for the optical drive are provided by the operating system, not Sony. The only download available (from Vaio-Link) would be a firmware update and unfortunately this is not offered for your model.
If the re-install of the drive recognised and installed the necessary drivers then, unless you are receiving any error codes, the chances are that the problem is hardware related and the drive will have to be replaced.
One last thing that you could try is cleaning the laser lens, but I really don’t expect that this will solve your problem.
