I'm looking for a car charger for my Vaio PCG k315z.
Can anyone point me in the right direction.
I get less than an hour from the battery and computer is < 14 months old.
The LaptopShop may be able to help you. Your model is not listed but if you give them a call they should have a compatible adaptor.
Thanks Rich
I have just started looking for one... so you have sorted me out too.
I am pleased that it was of help GBS. I did consider something similar but opted for an AC/DC power inverter, more bulky but multi functional.
i would recomend getting the inverter like rich sayed maplin sell one as well.
I have also started looking at an Inverter as my laptop (K115Z) needs 150W and none of the in car chargers delivers this much power, and as you say an inverter is more useful.
