i need to charge my lap top in the car a lot of the time and i was wondering if anybody knew what kind of adaptor i'm going to need to connect it to the car plug which is 12V.
thanks a lot
Hi sklsophia,
Try the Laptop Shop. If they don't have you model listed you may wish to consider buying a 12v DC/AC power inverter which will allow to plug in your standard adaptor directly.
